Remove Toilet Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2008, 02:21 PM   #1
Remove Toilet Rough in
Hello All,
I am finishing my basement and have decided not to install a bathroom. I now have the toilet rough in in the middle of the floor. What is the best way to remove this so that I can carpet over top of it. Adding the bathroom my be an option at some point in the future.
Thanks for the assistance.
Derek
dgoldb1 is offline   Reply With Quote
Old 02-05-2008, 02:25 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Open floor and cap it off.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-05-2008, 02:49 PM   #3
Is this something a DIY'er could pull off fairly easily? What all is involved?
Sawing down the PVC to floor level and installing a cap that fits inside the existing pipe with some type of epoxy or adhesive?
Old 02-05-2008, 02:51 PM   #4
Journeyman Plumber
Is this a slab floor, yes you have to cut pipe below floor line, either put in a plug inside or a cap over the top of the pipe, after you get it cut below the finished floor.
Old 02-05-2008, 03:06 PM   #5
Yes, it is a slab floor. It needs to be cut below the floor? How is this done?
Old 02-05-2008, 03:16 PM   #6
Journeyman Plumber
You may or may not need to chip out concrete, can't see it without picture, an inside pipe cutter like one seen below will allow you to cut below the floor line. If this cutter will work then use a inside pipe plug once cut.
Old 02-05-2008, 08:38 PM   #7
- cut it flush with the floor
- cram some balled up news paper down the pipe about 4” to 6’’ deep
- fill it up with hydraulic cement flush with the floor
dyier is offline   Reply With Quote
Old 02-05-2008, 08:43 PM   #8
Send a message via AIM to Marlin
- cram some balled up news paper down the pipe about 4 to 6 deep
First make absolutely sure that waste from elsewhere in the house doesn't share that line.
That is how a line is usually abandoned though.
Marlin is offline   Reply With Quote
Old 02-05-2008, 09:50 PM   #9
nah, leave it there. get a decorative toilet to use for a chair, table, or conversation piece. plus, if someone has a bathroom emergency it will be there.
nacko is offline   Reply With Quote
Old 02-05-2008, 09:57 PM   #10
Journeyman Plumber
I still prefer using a cherne expansion plug inside the line, but that just me.
Old 02-05-2008, 10:36 PM   #11
I like the idea of using the Cherne plug. How would I carpet over the wing nut though?
Would I want to use something like this?
http://www.cherneind.com/products-di...asp?pind=pp_10
Old 02-05-2008, 10:57 PM   #12
cut the pipe with an inside cutter (as shown in past post) low enough so the wing nut is below the floor
Old 02-05-2008, 11:06 PM   #13
Gotcha...I'll order one of these. Still up in the air about the expandable plug though. Not sure which one I need.
Old 02-05-2008, 11:22 PM   #14
Uh, the one in the pretty picture posted above. You just need to know if it is a 3" or 4" pipe. You need to measure the pipe to see.
Who Sells Them?
For sure:
- local plumbing supply company
Maybe:
- Home Depot
- Lowe's
- Ace Hardware
Old 02-05-2008, 11:30 PM   #15
Journeyman Plumber
Get one like the one I shown, however there are other type out there you just have to do some research on them. It will be a 3" or 4", depends on the inside diameter of the pipe your dealing with.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 02:34 AM
Shower Body, Toilet Water Supply Rough helpless handyman Plumbing 5 11-06-2006 09:51 AM
