Remove Stuck Water Filter Housing - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2012, 11:50 AM   #1
Remove stuck water filter housing
Hey all, I am trying to replace the filter in my GE smartwater GXWH08c and I for the life of me can't seem to get the housing off. I have turned off the water and used the pressure release button to remove the pressure from it. I have bough a strap wrench, and that isn't helping. I've tried to use WD-40 to loosed it up. Anyone else have any ideas / tricks / tips that I can try to remove the thing? Any ideas are definitely welcome, I'm at my wits end with it now.
Thanks,
James
jcolby is offline   Reply With Quote
Old 09-08-2012, 12:56 PM   #2
Instead of a strap wrench, use something like this which gives you more torque (http://www.filtersfast.com/GE-WX5X30...ter-wrench.asp)
BTW, I would not spray WD-40 near or on your water housing. Besides, the housing is plastic and the gasket is rubber so there is no rust.
allthumbsdiy is offline   Reply With Quote
Old 09-08-2012, 01:00 PM   #3
Rewards Points: 13,444
100% sure your turning it in the right direction?
Old 09-08-2012, 01:02 PM   #4
Thanks guys,
I was finally able to remove it. Just took a little bit more elbow grease, and a buddy to to stabilize the plumbing around it, so that I could really apply pressure.
Old 09-08-2012, 01:53 PM   #5
Water Treatment
Rewards Points: 850
The problems of having a filter with out any kind of bracket for the head to be mounted to the wall with...
Akpsdvan is offline   Reply With Quote
Old 09-08-2012, 07:25 PM   #6
Rewards Points: 582
when reintalling housing..apply a little vasoline to oring and top where it meets this will make it easier to remove next time...ben ..
Old 09-08-2012, 07:56 PM   #7
Water Treatment
Rewards Points: 850
Vasoline?
That could most likely the worst idea yet.
There is some silicon out there that is safe with water use or find another o ring in a plastic bag and most likely there is a little tube of the silicon and it does not take much.
Vasoline will break down and make a real mess of the housing and get into the water.
Old 09-08-2012, 08:17 PM   #8
My water filter did not come with a mounting bracket so I simply installed a 1/2" pine backerboard and secured the top filter housing with a metal strap.
Since we drink and cook with this water, I avoid using any type of synthetic petroleum or water-based lubricants. Instead, I simply use some olive oil to lubricate the gasket.
Tags
ge smartwater , gxwh08c , stuck , water filter
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Black material in water filter Sartrean Plumbing 4 03-09-2012 05:31 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Connecting Water Filter Housing to CPVC Pittsville Plumbing 7 01-20-2011 02:01 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
