Remove Stem From Old Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2011, 10:35 AM   #1
Remove Stem from Old Faucet
I am trying to remove the stem from this old Speakman tub faucet. It looks like I have removed everything that I should. Does anyone know if the big nut that is left needs to be removed? Any guidance appreciated.
Remove Stem from Old Faucet-img_2354_small800.jpg   Remove Stem from Old Faucet-img_2353_small800.jpg
kosherman is offline   Reply With Quote
Old 06-21-2011, 05:26 PM   #2
yes, that is your bonnet nut, you need to remove it and the stem should come out
just a guy is offline   Reply With Quote
Old 06-22-2011, 10:40 AM   #3
Much appreciated. Any advice greatly welcomed and appreciated.
Old 06-26-2011, 02:15 PM   #4
kosherman, I have an almost identical tub faucet (1925 Speakman) that I need to replace the valves because a previous owner ditched the originals and replaced them with American Standards. The only difference I can see between yours and what I have is that I need stems with a 3/8" square end. My handles and escutcheons are identical other than the broach opening. Is there any chance you could post a picture of the valve when you get it out that shows how big it is? I have had no luck getting this info anywhere else and I am unable to post my own photos on here. Any help would be appreciated. Thanks!
triciam is offline   Reply With Quote
Old 06-27-2011, 10:45 AM   #5
Here is what the stem is looking like when I finally got it removed. Thanks for the guidance.
The Following User Says Thank You to kosherman For This Useful Post:
triciam (06-27-2011)
Old 06-27-2011, 11:59 AM   #6
Thanks so much! I am trying to figure out a way to get my photos on here, the jpegs are too big and I'm still trying to figure it out, but the valve body of my faucet sticks out from the wall about an inch, so I'm guessing that I would need a stem about an inch shorter, although I suppose it really wouldn't matter as long as everything is well attached. Does your waste handle have a splined broach like your faucet handles? Is the stem all you need inside the the faucet or are there more parts to it?
Old 06-27-2011, 12:24 PM   #7
Okay, got some photos up on my thread finally, sorry I'm bombarding you with questions, you are the only person I have found with my type of faucet, thanks for your help!
help removing faucet stem eric447167 Plumbing 13 08-11-2011 10:08 AM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Bathtub faucet stem seat is frozen and won't turn. Husky Plumbing 1 04-01-2009 01:35 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 01:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
