Remove Saddle Valve For Ice Maker Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2011, 08:05 AM   #1
Question
Remove saddle valve for ice maker line?
So I am moving and was disconnecting my ice maker line. It it a saddle valve that self pierced the line. I applied it to the water line before the shut off valve. I assumed if you tightened the valve stem it would seal off the line. It does not. Now it is leaking 1/2 gallon/day. Any suggestions on what to do? Please and thank you!
redge03 is offline   Reply With Quote
Old 11-17-2011, 08:19 AM   #2
Chicago, IL
Michael Thomas's Avatar
Most saddle valves will leak eventually, that's where they are prohibited by the state plumbing code here in Illinois.
First question: when you say you "tightened the valve stem", are you referring to (1) the "handle" (usually a "T" shape on these valves) or (2) the packing nut, which surrounds the valve stem and screws down onto the body of the valve. If you have not yet tried tightening the packing nut, tightening it 1/8 to 1/4 turn, and see if that stops leak.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
redge03 (11-17-2011)
Old 11-17-2011, 10:31 AM   #3
AlbacoreShuffle's Avatar
Id just remove the valve and plug it with Mighty Putty,
Billy Mays says this stuff will fix any thing !
AlbacoreShuffle is offline   Reply With Quote
Old 11-17-2011, 11:35 AM   #4
Rewards Points: 93
[quote=AlbacoreShuffle;773300]Id just remove the valve and plug it with Mighty Putty,
He is also the LATE Billy Mays so the warranty is probably over
George6488 is offline   Reply With Quote
Tags
ice maker , saddle valve
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
dry water line to the foot valve ksbnellis Plumbing 0 06-06-2011 11:37 PM
Can't remove bath tub handle valve stem. kuyaariel Plumbing 13 05-02-2011 11:20 PM
cost - leak on main water line and changing valve sandrashand Plumbing 13 01-15-2011 07:56 AM
hook up ice maker line. already have a valve on the floor behind fridge but...3/8" bakchoi Plumbing 5 11-25-2008 06:59 AM
