Remove / Repair Shower Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2013, 01:32 PM   #1
Remove / repair shower cartridge
The plastic limiter on my shower cartridge broke and it's hard to regulate the on/off and temperature (and dangerous for my small child).
Picture attached and could use some help with several things.
1. This is as far as I have made it. What's the next step to get the cartridge out?
2. Does the cartridge need to come out or can I just replace the green plastic part that broke (if it will come out separate from the rest of the cartridge)?
3. Not sure what kind of cartridge I have, but assume I can figure it out once it's removed.
Thanks for any help you can give.
Remove / repair shower cartridge-20131117_141848.jpg
impact18 is offline   Reply With Quote
Old 11-17-2013, 02:35 PM   #2
DIY staff
Rewards Points: 7,174
What brand is it?
Old 11-17-2013, 02:37 PM   #3
Not sure of the brand. No indication on the knob or faceplate.
Old 11-17-2013, 03:12 PM   #4
DIY staff
That mixer valve has its own shut off stops---so you could shut off the water using the stops---I seldom do that ,however, as I have had them break---your call--
To remove the cartridge---grip the chrome collar and unscrew it---the cartridge can be wiggled out after that---take the old cartridge to the plumbing supply house and see if they stock one like it---the new cartridge should have the plastic stop rings--
If that is a Delta-(looks rather like one) you could get free parts from the manufacturer---however--without knowing the maker---you are best to just buy a replacement after the plumbing supply identifies it.
One of our plumbers might recognize what you have---so check back later---Mike---
Old 11-18-2013, 12:39 PM   #5
Rewards Points: 338
looks like i can see some writing stamped on the housing. i would think that would have the brand on it.
NitroNate is offline   Reply With Quote
No flow from Delta 1700 shower valve after cartridge replacement billyjoe Plumbing 11 04-24-2016 02:42 PM
Shower floor repair pinkertonpv Kitchen & Bath Remodeling 18 08-23-2012 09:03 PM
How do I remove this shower faucet cartridge? Tco0085 Plumbing 5 07-14-2012 10:14 PM
trying to remove tub faucet cartridge trolleyman Plumbing 1 06-10-2011 06:57 AM
broke moen shower cartridge pin in half jeanne p Introductions 1 08-17-2010 10:15 PM
