-   -   Remove / repair shower cartridge (http://www.diychatroom.com/f7/remove-repair-shower-cartridge-190527/)
impact18 11-17-2013 01:32 PM
1 Attachment(s)
The plastic limiter on my shower cartridge broke and it's hard to regulate the on/off and temperature (and dangerous for my small child).
Picture attached and could use some help with several things.
1. This is as far as I have made it. What's the next step to get the cartridge out?
2. Does the cartridge need to come out or can I just replace the green plastic part that broke (if it will come out separate from the rest of the cartridge)?
3. Not sure what kind of cartridge I have, but assume I can figure it out once it's removed.
Thanks for any help you can give.
oh'mike 11-17-2013 02:35 PM
What brand is it?
impact18 11-17-2013 02:37 PM
Not sure of the brand. No indication on the knob or faceplate.
oh'mike 11-17-2013 03:12 PM
That mixer valve has its own shut off stops---so you could shut off the water using the stops---I seldom do that ,however, as I have had them break---your call--
To remove the cartridge---grip the chrome collar and unscrew it---the cartridge can be wiggled out after that---take the old cartridge to the plumbing supply house and see if they stock one like it---the new cartridge should have the plastic stop rings--
If that is a Delta-(looks rather like one) you could get free parts from the manufacturer---however--without knowing the maker---you are best to just buy a replacement after the plumbing supply identifies it.
One of our plumbers might recognize what you have---so check back later---Mike---
NitroNate 11-18-2013 12:39 PM
looks like i can see some writing stamped on the housing. i would think that would have the brand on it.
