Remove Cast Iron Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2007, 06:10 PM   #16
Carpenter/Builder
neolitic's Avatar
Originally Posted by neolitic View Post
You should give serious consideration to dropping it down below the ceiling, and building a bulkhead around it.
Those joist have been butchered, and should be sistered, with full virgin 2X8's.
They really shouldn't have a hole larger than 2-2".
You can cut the pipe with anything, sawsall, chain cutter,hack saw.
That's not a problem!
Those joist ARE a problem.
This is what I do for a living, for more than 35 years.
Originally Posted by amakarevic View Post
no pipe should go through a beam, much less beamS, it should be parallel with the beams, otherwise the entire structure is weakened.
My point exactly!
neolitic is offline   Reply With Quote
Cast iron vs galvanized steel. duffers Plumbing 10 08-04-2009 10:35 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
Old cast iron pipes heather92 Plumbing 2 04-10-2007 08:36 AM
Heating Oil Pipe Removal Big Bill Plumbing 26 09-17-2006 06:56 PM
