Remove Bathroom Sink From Cabinet Stuck With Silicone - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2010, 12:02 PM   #1
Remove bathroom sink from cabinet stuck with silicone
i just recently attached a new bathroom sink to a (IkEA) cabinet using slicone. during the installation and attaching the plumbing the sink moved on the cabinet (but i didnt notice).
Now the sink is stuck to the cabinet but in an off postion.
I am trying to use blowdryer to loosen the silicon and pry it off but its not working that well and have good chance of damaging things.
Suggestions?
Bucker is offline   Reply With Quote
Old 09-08-2010, 04:47 PM   #2
Suggestions?
razor to cut the silicon then scrape it all off, start over
amdspitfire is offline   Reply With Quote
Old 09-08-2010, 05:08 PM   #3
Suggestions?
hammer
the_man is offline   Reply With Quote
Old 09-09-2010, 01:02 PM   #4
rip the ikea counter and sink out and go get yourself a granite vanity with a under mount or vessel sink ...it will look much nicer
most granite shops can make a vanity in less than 4 hours
and more like 1/2h if you have a vessel sink
blunt22man is offline   Reply With Quote
Old 09-09-2010, 01:25 PM   #5
Rewards Points: 79
wow - after reading the suggestions i feel i have to offer sympathy. The neatest tool I have for precisely such situations is an OLD candy spatula. It was my grandfathers - from the 1920s. Reason I mention this is - it is A. thin and long - think extended well made putty knife. B it is strong and sharp. The razor suggestion is good - and if you are CAREFUL and the seal is mostly perimeter (inside and out) you might be able to pull that off. But if there is a bond on the thickness of the edge, you'll need to carefully work a very thin, sharp tool or instrument through that bond. If you can - without craning your neck and ending up with a stiff neck for a week- work this from the inside of the cabinet. reducing the chance of scraping the finish. If you must go at it from the outside, Tape the boarder beneath the top a few layers of 2 inch masking and go at it slow and carefully.
There are products that will weaken silicone as well, but I caution you on using them near wood as the finish may become stained or damaged.
Just a heads up -- Whenever you place a top such as this on a vanity, it is good to Set the top and after it is EXACTLY where you want it, Mark the bottom side with a VERY SHARP POINTED pencil. Then, flip the top off - and adhere small 90 degree corner blocks using the marks as guides. these blocks can have a slight taper downward - away from the top to make installing the top easier. Then Install the top - using the silicone and LET IT CURE before installing the fixture. Of course the other way would be to - install the fixture to the top - have it exactly where you want it - making sure the connections to your supply lines and drain pipe will be easy, make those marks I spoke of, and proceed. But don't go bumping things around til they're cured.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Old 09-10-2010, 03:15 PM   #6
Rewards Points: 352
fein multitool
plumberinlaw is offline   Reply With Quote
PVC vs FMC vs AC vs ENT for cabinet under kitchen sink? tigereye Electrical 1 02-21-2010 09:28 PM
bathroom sink & wall dknarnd Remodeling 1 01-24-2010 11:56 PM
replacing bathroom sink & it's stuck michee Kitchen & Bath Remodeling 11 08-17-2009 08:59 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 12:24 PM
