Old 09-11-2012, 11:40 AM   #1
Removal of Tub Spout
My tub spout has been leaking when the shower was on, so after some research, I found that it is probably the diverter and the spout needs to be replaced. I was able to remove the spout, but there was not a nipple behind the wall for the new spout to screw onto. Instead, there was a threaded protrusion from the old spout that screwed into the wall. I have researched and have not been able to determine what type of connection this is. Now I am a complete novice at plumbing. Does anyone know what I would need to replace the spout?
Remski is offline   Reply With Quote
Old 09-11-2012, 11:59 AM   #2
Post a picture. Could be anyone of at least three differant types.
Old 09-11-2012, 12:09 PM   #3
Super Moderator
The 1/2' threaded nipple came out with the spout----you do have a threaded flange inside the wall----take the old spout the the store with you----find a 1/2" nipple that will extend out the back of the new spout just as far as the old one does----(allowing for tightening up the parts)---and you should be okay.
Removing Stubborn Tub Spout 347Cougar Plumbing 6 12-27-2012 04:12 PM
Removal of tub with delta roman spout, faucets John stockdill Plumbing 12 09-11-2012 10:12 AM
where do I set the black o- ring on the tub spout? or the threaded copper pipe? radioflyer77 Plumbing 1 07-05-2012 10:23 PM
Frustrating bath spout removal problem martinvancouver Plumbing 6 07-09-2009 01:38 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 04:41 PM
