Removal Of Tub With Delta Roman Spout, Faucets - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-11-2012, 08:04 AM   #1
Removal of tub with delta roman spout, faucets
I am in the process of remodeling our master bath with a roman tub. The tub needs to be removed. Faucets came off fine but I can not figure out how tp remove the spout nipple. The home was built in 98.
John stockdill is offline   Reply With Quote
Old 09-11-2012, 08:10 AM   #2
DIY staff
Rewards Points: 7,174
Can you post a picture of the stub? Most have a top nut like the faucets---
Old 09-11-2012, 08:16 AM   #3
DIY staff
Are you talking about the spout itself?
Old 09-11-2012, 08:23 AM   #4
Sorry, no pic. The nipple has threads on two sides and is flat on the other two. The nipple sits on a washer which covers the hole in the tub which the assembly sits in. I think I am going to have to break into the frame surrounding the tub.
Old 09-11-2012, 08:26 AM   #5
Not the spout that came off easy. Kane co. Used to live in St. Char
Les.
Old 09-11-2012, 08:27 AM   #6
DIY staff
Have you put a wrench on the flats and tried to unscrew it?
Old 09-11-2012, 08:29 AM   #7
DIY staff
I'm right off the river just north of the ground cover place
Old 09-11-2012, 08:33 AM   #8
No, am concerned that might damage rough in. Was told there might be a lock nut underneath that needs to be removed before it can be unscrewed. I am trying to save the rough in assembly.
Old 09-11-2012, 08:35 AM   #9
Where is ground cover place? We were out in the Windings late 70 early 80
Old 09-11-2012, 08:43 AM   #10
DIY staff
east of the river---from Macks Silver Pheasant (now closed) north to Gilbert--(the Railroad and the old Quonset hut) where Dunham and 25 merge ---You would not recognize the area any more--Lots of new roads--two new bridges----one at Redgate road where the Little Woods School used to sit--another north of there parallel to the Great Nothern RR bridge---
About your faucet spout stub---are you sure the washer is not a nut threaded onto the threaded stub?
Old 09-11-2012, 08:51 AM   #11
Ol mike, thanks for the chat. Sounds like a lot of changes out there. We are in fla now no snow! That was my thought at first. I was able to turn the washer but it did not loosen and there are no grips like the faucets have on their washers. I don't know about you but these little projects always turn into more than anticipated.
Old 09-11-2012, 08:59 AM   #12
DIY staff
I spend a lot of time doing plumbing---and still run into goofy delays---
If the tub and faucet are going to be junked---You may wish to cut an access and see whats going on from below---
Old 09-11-2012, 10:12 AM   #13
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You definitely don't want to try spinning that spout, especially with the delta R.I. valve.....
You're going to need access below.
http://imagethumbnails.milo.com/008/...83_trimmed.jpg
Hope that helps you.
Journeyman Plumber
Delta Roman Tub Faucet Upgrade Issue gunderwo Plumbing 4 05-31-2012 09:40 AM
Delta Bath Faucet Leaks rtrinkle Plumbing 3 12-13-2011 08:44 AM
Removal of Delta Delex roman tub filler Larryinlakeo Plumbing 0 09-30-2011 03:27 PM
Removing Delta Roman Tub Spout stanart Plumbing 1 10-31-2010 06:20 PM
Frustrating bath spout removal problem martinvancouver Plumbing 6 07-09-2009 01:38 PM
