Old 10-13-2009, 11:25 AM   #1
Default Removal of Bathtub Drain
When attempting to remove the tub drain, using a "dumbell wrench" It was very tight. In my attempt I completely broke the crosshairs in the drain. How can I now remove the drain? I had to chisel around the drain edge to remove the tub. Now I have to find a way to remove the drain in order to install the new tub. Thank for any help you can give.
joe3534 is offline   Reply With Quote
Old 10-13-2009, 12:37 PM   #2
If you are replacing the tub it is time to replace the waste and overflow anyway. They are cheap and probably easier than working with the old one. Is there a reason you ar trying to save the old one? Usually I replace the trap also unless it is a newer pvc or abs trap and in good shape. Doing so could save you some big expensive problems down the road.
Rege
RegeSullivan is offline   Reply With Quote
Old 10-22-2009, 10:33 PM   #3
I removed the drain in my bath tub, in the process I made a cut in the threads of the shoe below the tub, it did not cut all the way, but cut deep enough to down to the bottom of the thread in a u shape line. I am thinking to solder that grove and screw the new drain on top. not sure if this would work, or i will have a leak. Would caulking work to seal it or glue. I hate to replace the shoe pipe, it will be lots of work. Any advise?
NewPlumber is offline   Reply With Quote
Old 10-22-2009, 10:34 PM   #4
Old 10-22-2009, 10:41 PM   #5
Master Plumber/Mechanical
If you are a plumber then get to work and replace it. Do it right.
If you are not a plumber then get to work and replace it. Do it right.
Any way..looks like you have alot of work
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
More On This Topic
You may have noticed the caulk around your tub peeling off or cracking. You may also think, "I have no tools! I can't fix that!" Sure you can! Fixing tub caulk is easy. Read More »
When you’re caulking around a tub or a sink, it’s important to dig out the old caulk first, especially if it’s grown some mold, because that will just go through the new caulk. So, it’s a little bit tedious, but it really is... Read More »
So now that we’ve got all our pieces on, all nailed and tight, the next step is to fill the nail holes and caulk the cracks wherever they may be. So this is just a standard caulking gun, very easy to use, standard caulking interior white is... Read More »
Keeping your bathtub clean means cleaning it weekly and maintaining it daily. If you do this, and follow the steps provided, you'll save yourself a lot of scrubbing and you'll keep your tub looking nice and clean. Read More »
Hi! I'm Matt Cail on behalf of Expert Village. I am here to tell you today how to set up and play bobbing for apples. Now that we have our apples, the next step is to get our tub or container that we are going to be putting the apples and water in. There... Read More »
Bathtub drain replacement ex-Khobar Andy Plumbing 1 07-15-2009 06:17 AM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 5 04-20-2009 11:37 PM
Bathtub drain - subgrade jdeters79 Plumbing 3 11-21-2008 05:17 PM
Bathtub Drain - HELP! Terike Plumbing 4 10-05-2008 01:50 PM
Bathtub drain location kendallk Plumbing 3 11-11-2007 01:02 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
