Removable Cap On Water Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2012, 01:33 AM   #1
Removable cap on water line?
There is a capped off copper water pipe stub running vertically from basement ceiling level. The previous owner had planned to install a sink. I need to make a repair on the line so need to drain the water for soldering.
Would it be possible to use some sort of removable cap in place of a soldered one at the end of the stub to facilitate future draining? Is using a copper threaded adapter with a brass cap or plug acceptable?
Thanks!
olivedal is offline   Reply With Quote
Old 12-03-2012, 04:28 AM   #2
DIY staff
Rewards Points: 7,174
Buy a compression ball valve like the ones under your sink----use that---
joecaption (12-03-2012)
Old 12-03-2012, 09:55 AM   #3
Special User
Rewards Points: 1,230
Brass is compatible with copper and they do make sweat-to-thread fittings. But oh'mike's solution is way easier and probably costs the same.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 11:19 AM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
