Remodeling Laundry - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2012, 07:38 PM   #1
remodeling laundry
Is it ok to put water lines in the outside wall of my house or will that be a freezing hazard?
florpro is offline   Reply With Quote
Old 01-13-2012, 07:46 PM   #2
jproffer's Avatar
Rewards Points: 706
You wouldn't be the first that did it, but yes it might freeze. Is there access from below? If so you could run them under their from farther into the house and bring them up behind the washer, but not inside the wall.
Need more details...or pictures
jproffer is offline   Reply With Quote
Old 01-13-2012, 07:48 PM   #3
DIY staff
Rewards Points: 7,174
If we knew your location some one could answer that.
The answer to that is DON"T DO IT if you live in a cold area---
Old 01-13-2012, 08:07 PM   #4
Rewards Points: 13,274
It's simple enought to build another wall in front of the other one, that way the lines come throught the floor but all the plumbing is hidden.
Often times I'll build the wall so it comes out above the washer and dryer and add a shelve on top of that to set the laundry soap on.
Old 01-13-2012, 08:08 PM   #5
I live in Lancaster, pa
Old 01-13-2012, 09:05 PM   #6
Rewards Points: 582
yes it gets very cold there in the winter time.....avoid outside wall if at all possible...if not super insulate and still pray...
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 10:12 AM
Need Advice on Laundry Water Box Location txnbink Plumbing 0 09-26-2011 02:42 PM
Remodeling laundry closet bplaird Carpentry 11 05-09-2011 06:44 PM
Laundry Room Addition Completed hyunelan2 Project Showcase 6 02-27-2011 11:42 PM
Angled Laundry Chute Fox Remodeling 10 06-01-2010 12:09 PM
