-   -   remodel - 2 sinks now but 1 previously (http://www.diychatroom.com/f7/remodel-2-sinks-now-but-1-previously-192004/)
stadry 12-14-2013 09:27 AM
good idea or not ? replace sgle sink vanity w/new dble sink base - that part's good as we have the room BUT can i ' T ' off the existing drain & couple the 2nd drain into it ? new vent pipe for the 2nd sink or live w/gurgling ? would also have to ' T ' off existing supply lines to run to new sink,,, pretty sure shutoffs on existing supply & EACH sink are a good idea, too,,, thanks, guys ! appreciate the help !
joecaption 12-14-2013 09:55 AM
http://www.bing.com/images/search?q=...electedIndex=7
Only one drain line is needed. If the one you have now is vented then there's no need for another vent.
You can buy the whole set up for a double sink in any box store. It will come with a tee.
stadry 12-14-2013 10:24 AM
thanks, joe,,, kinda what i thought but better to ask now than hear buyer's ' home inspector ' give a low whistle as he calls to his helper - ' hey, come look at this ! :censored:
imagine the existing is vented as it don't gurgle now :laughing: you're my best friend for the next 4 hrs
' box store ' = gggrrrrrrrrrrrrrrrrr:furious:
TheEplumber 12-14-2013 10:52 AM
199 Attachment(s)
Two sinks are doable but you need to watch the trap arm length under the counter. If you go too long you could have gurgle or siphon problems.
Also code requires each fixture to have their own shut offs. You will need to tee off the water lines to do this.
All said- it would be better to open the wall and use a drainage fixture cross or stack to tees. While in the wall move the waters as needed.
stadry 12-14-2013 02:56 PM
' trap arm length ', e ? ' too long ' = total length of pipe from p-trap to drain/vent ? how's that defined ? will open wall to run drain & vent
code compliant on the rest - ' tee's ' & shut-off's :thumbsup:
thanks, e !
TheEplumber 12-14-2013 05:22 PM
199 Attachment(s)
thanks, e !
Take a look at paragraph 1001.2 in this link. http://www.iapmo.org/California%20Pl...apter%2010.pdf
This is from the UPC- the code I work under- not sure if it covers your area.
You're interested in the section that talks about lavs.
2 lavs will work on 1 trap if within 30"- kind of like a double bowl kitchen sink.
Something to check out prior to starting- some lavs are stubbed out of the wall with 1.25" pipe
Only 1 lav can be put on 1.25" - another reason I'd open the wall.
You mentioned a home inspector- who knows what he'll find "wrong"- or miss on a walk through. I've gone out and punch listed inspection reports for clients before. I always have a good laugh- "fixing" things that are code compliant because some guy wrote it up.
Edit: that link also shows trap arm lengths in table 10-1. You're interested in 1.25" or 1.5"
Again- this is UPC- IPC are longer lengths.
Ghostmaker 12-15-2013 12:41 AM
Under IPC the 2 lavs require a 2 inch drain if the are the wet vent.
stadry 12-15-2013 06:18 AM
10-4 on fixing things that don' need no steenkin' fixin' :thumbup: ' wet vent ' ? wtfizzat ? this is gettin' complicated,,, i'll jus' give your names to the inspectors :furious:
will get into it today,,, thanks, both !!!!!!!!!!!!!!!!!
Ghostmaker 12-15-2013 01:50 PM
Please do perhaps this inspector can explain IPC to him...
Javiles 12-16-2013 09:21 PM
wet vented or wet bend..:yes:
stadry 12-18-2013 05:09 AM
i get it - that's plumbing-craft/trade humor, right ? :laughing: we'll use the right stuff & do it the right way,,, mikey's my licensed plumber & knows code,,, all i wanted to know is IF its legal,,, thanks, guys,,, you're a great resource
thanks again !
