Relocating Water Heater To Backyard. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2008, 04:30 PM   #1
Rewards Points: 150
Relocating Water Heater to backyard.
I was wondering if any one has a slight idea of how much it would cost me to relocate the water heater. Currently the heater seats pretty much in the middle of the house (a hallway closet). I would like to move it to the back of the house. I just feel safer about the heater being outside of the house (on the back). What recomendations or warnings can you give me before I make any decision?
by the way, I live in southern california (san bernardino) if this makes any difference.
Greg
gante is offline   Reply With Quote
Old 03-06-2008, 06:14 PM   #2
biggles's Avatar
if it is gas beng outside will cut down on its life,if it's electric it shouldn't make a diiference.when was the last time you blew off the relief or flushed the tank itself out?
Old 03-06-2008, 08:48 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
You did not supply enough info to give any kind of an estimate, very little info supplied.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-07-2008, 09:30 AM   #4
Rewards Points: 150
This would actually be a "new" house to me. The house is kind of a fixer upper. I am not living there yet but this heater would be on my to do list. Is not a priority but just something I would like to do in the near future. What type of information would be required in order to give you a better idea to help me?. I believe the heater is gas and not electric. Even if I enclosed the heater to protect from the elements will it shorten its life to relocate to the back of the house?
thanks
Old 03-07-2008, 02:26 PM   #5
Rewards Points: 682
I would personally not recommend doing this at all. Just replacing a heater costs $800 to $1300. I would think moving it out back could be more costly since you would have to rip out the walls and run a line to where the old water heater used to be, (and run a new gas line outside?), build a structure to hold the tank outside, build a new flue to handle the exhaust gases, etc. Also there is the risk of water pressure problems at the fixtures and longer wait for the hot water taps to become hot.
A fixer upper is a costly affair whether it is for yourself or if you plan to flip the property. Why add a huge expense when it is probably not necessary? Unless you have money to burn.
darsunt is offline   Reply With Quote
Old 03-07-2008, 05:22 PM   #6
Rewards Points: 150
Yes you are right, it was just a thought but it seems to involve a lot more work and cash than I anticipated.
Old 03-07-2008, 05:42 PM   #7
Journeyman Plumber
Yes it won't be cheap to move the tank.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
