Relocating Washer/Dryer A Few Feet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2011, 11:05 AM   #1
Relocating Washer/Dryer a few feet
I have some questions regarding relocating my washer and dryer a few feet from where they currently live in the kitchen. I want to make a new laundry closet off of the main hallway.
The red dot
is the existing drain pipe and washer supply in the wall in the kitchen. It is a shared drain with the bathroom sink behind it.
existing layout:
Relocating Washer/Dryer a few feet-layout.jpg
proposed layout changes:
Relocating Washer/Dryer a few feet-layoutnew.jpg
So, the questions:
1. Can my planned changes be done without moving the existing drain pipe? I will get a plumber to add some new supply lines if/when necessary, but I don't want to have to have any concrete work if not truly necessary.
2. Can the dryer vent be vented into the attic and then out elsewhere without problems? Right now it's vented out through a duct through the lower kitchen cabinetry.
A picture of the kitchen for reference:
Thank you for your help,
Nate
Come by and visit our renovation 'blog': '59ish Brick Ranch: Updating... everything...
natedro is offline   Reply With Quote
Old 12-20-2011, 04:12 PM   #2
64 views and no advice? Help!
Old 12-20-2011, 04:50 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
1. very possible to plumb without breaking slab, but not for sure- need to see existing roughin.
2. I don't know
Old 12-20-2011, 05:52 PM   #4
DIY staff
Rewards Points: 7,174
Can't tell without opening up the wall--sorry--
Old 12-20-2011, 09:34 PM   #5
Rewards Points: 582
yes I agree with the others however imo it should work..drain that is.... all that should be needed is to extend drain to new location inside wall ..I would be alittle concerned about the vent though..water line not a problem...
Old 12-23-2011, 10:41 PM   #6
I'm not certain it is vented now. Would I simply go in the attic and look for a pipe upward to determine that? House was built in 1959 and laundry seems to be a later addition.
Old 12-23-2011, 10:46 PM   #7
Rewards Points: 582
yes you can look in attic to see if it has a vent......washer is draining in the same drain now that you are talking about moving right.....its working now ......should work after it is moved a few feet......just that we have to plumb to code ....vent is needed to meet code
Old 12-23-2011, 10:51 PM   #8
yes you can look in attic to see if it has a vent......washer is draining in the same drain now that you are talking about moving right.....its working now ......should work after it is moved a few feet......just that we have to plumb to code ....vent is needed....
Oh OK I understand. Is adding a vent a large job/expense for a plumber (or maybe even a homeowner)? Also no one has mentioned the dryer vent. Any input on that? Thank you by the way and happy holidays.
Old 12-23-2011, 10:55 PM   #9
Rewards Points: 582
where is the dryer vented now???? vent not a big deal just a very good idea for proper operation.....
Tags
dryer , relocation , vent , washer
Outlet placement jerseyguy1996 Electrical 47 02-06-2013 02:32 PM
Relocating a 200 amp service RBlack Electrical 1 05-23-2011 01:27 PM
Newbie needs to build a deck addition toolbot Building & Construction 16 05-10-2011 12:58 PM
Lets Play The "How Much Stain Will I Need?" Game! Bgm94 Painting 5 02-11-2011 10:53 AM
Extend height of interior balcony railings by feet? denemante Building & Construction 5 10-23-2010 05:18 PM
