Relocating Tub And Shower Stall - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2009, 07:46 PM   #1
relocating tub and shower stall
Im remodeling my bath,and i moved my tub about 4 feet from the drain in the cement floor, and i want to also install a shower stall between the tub and drain----do i need to jackhammer a new pit and ditch to the drain thats there so that i can add new pee traps --under these new items--- thanks
dickielee is offline   Reply With Quote
Old 08-13-2009, 08:05 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Sounds like a good plan. Don't forget about the vent for the shower.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-14-2009, 11:58 AM   #3
help
Thanks--since both the tub and shower will drain into the 1-1/2 can i use a vent--AAV--if so where could i locate that ---i appreciate any info--im just a do-it yourselfer--thanks
Old 08-14-2009, 06:51 PM   #4
Rewards Points: 560
There's your next problem.
Code reuqires a min 1 1/2" for tub drain and 2" for shower.
