Relocating Toilet Flange And Main For Basement Bath. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2013, 09:29 AM   #1
Rewards Points: 212
Relocating toilet flange and main for basement bath.
I want to relocate this but there is terra cotta line
blocking it. Either have to go under or over, i guess. Best option seems to be go under if its ok to have a big main p trap under slab??
If I go over, barely enough room for a slab, maybe 1/2" to 1". Not to mention new flange for toilet will be way too high.
Can I go under with some 90's? Will it need a clean out?
Squeakyhinge is offline   Reply With Quote
Old 04-13-2013, 09:45 AM   #2
Rewards Points: 212
After posting, I started thinking maybe just move the toilet a little to the left instead of trying to go around the terra cotta line.
Next challenge:
If I move it to the left can the y go in the direction displayed coming from lav and shower?? Disregarding the extra y on the other side.
Old 04-13-2013, 09:52 AM   #3
Rewards Points: 212
This is the plan:
Have to get some clearance between the toilet and shower. The shower can't move because there is an I beam along the ceiling parallel to the adjacent wall. Not enough height.
Old 04-14-2013, 07:05 AM   #4
Rewards Points: 212
Bump.
Old 04-14-2013, 07:11 AM   #5
DIY staff
Rewards Points: 7,174
What are you going to do with the double Y fitting that you show attached to the toilet bend?
As installed ,you will fill the two inch pipes with sewage every time the toilet is flushed--
Squeakyhinge (04-14-2013)
Old 04-14-2013, 07:28 AM   #6
Rewards Points: 13,228
And what's that old tile line for?
At some point it's going to fail and need to be dug up and replaced.
Looks like now would be a good time to do it.
Old 04-14-2013, 07:50 AM   #7
Rewards Points: 2,516
Are you planning on sending toilet waste into your shower line? Because with that wye you have positioned the way you do like oh'mike said everytime you flush the commode some sewage will go into the shower branch.
Not to mention how would you expect the shower to drain into the wye and take that 135 degree turn???
Or maybe everyone is just misunderstanding your intention??
hammerlane is offline   Reply With Quote
The Following 2 Users Say Thank You to hammerlane For This Useful Post:
oh'mike (04-14-2013), Squeakyhinge (04-14-2013)
Old 04-14-2013, 09:11 AM   #8
Rewards Points: 212
I have a toilet, lav, and shower that have to go to this "main outlet". I need to know how to properly "route" the lines.
Maybe I have to put the toilet to the right of existing position. Or Y everything right above the main outlet with a straight 4 with a 2 out the side?
Old 04-14-2013, 09:16 AM   #9
Rewards Points: 212
Not sure what's up with the tile line. I could sketch a layout of what I think it's for. But guessing the basement floor drains and main sewage are two separate lines leaving the house. It's 80 yr old house. It's heading right for an outside wall. I could replace yes and maybe just junction with the other line??
Old 04-14-2013, 09:22 AM   #10
Rewards Points: 212
So just reverse the Y direction and its ok??
I'm really limited by where I can place things in this space and that main is in a bad spot for where things must be placed and there's a terra cotta pipe next to it limiting the position of the toilet to somewhere only on that wall but not in the middle where it is now.
Old 04-14-2013, 09:28 AM   #11
Rewards Points: 212
Here's a sketch.
Old 04-14-2013, 09:30 AM   #12
Rewards Points: 212
The top and left are outside foundation. The bottom wall, btw, has a low I beam parallel to it.
Old 04-14-2013, 09:32 AM   #13
You need to take a photo standing further back and designate where your main line is, where you are putting your toilet, shower and lav.
By the way have you thought about how this bath group is going to be vented?
Edit: looks like you posted the drawing as I was posting this response.
The Following User Says Thank You to hammerlane For This Useful Post:
Old 04-14-2013, 09:41 AM   #14
Rewards Points: 212
Not sure about extra venting. I was told the vents are supposed to be up to the ceiling, at least. No, I haven't thought about it.
Old 04-14-2013, 09:47 AM   #15
You should consider it. They are required.
Relocating toilet flange and main for basement bath.-1625s.jpg   Relocating toilet flange and main for basement bath.-p_vent.jpg
3" ABS toilet flange 3 1/2" too high in basement floor fusion2k Plumbing 3 08-26-2012 01:41 PM
Toilet flange to main line 18" drop and 15" run can it be done??? ChrisDIY Plumbing 5 01-06-2011 09:35 PM
Toilet Flange Questions LeviDIY Plumbing 13 06-04-2009 02:22 PM
Rotten toilet flange and sunken slab mcmarsha67 Plumbing 1 01-17-2009 02:41 PM
