Relocating A Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2012, 06:35 AM   #1
Experienced
Naz1298's Avatar
Relocating a toilet
How easy is it to relocate a toilet? Let's say we are moving it 3 feet to the right and rotating it 90 degrees.
Naz1298 is offline   Reply With Quote
Old 01-21-2012, 06:39 AM   #2
Thread killer
Rewards Points: 272
It could be really easy or impossible. How about grabbing a pic or two of the bathroom in question?
Canucker is offline   Reply With Quote
Old 01-21-2012, 06:56 AM   #3
DIY staff
Rewards Points: 7,174
Concrete floor or wood frame?
Open framing under toilet or finished room?
Old 01-21-2012, 08:31 AM   #4
MarginallyQualified
Rewards Points: 2,464
I'll be doing two later this year.
I have complete unhindered access from the full height basement below.
and the joist layout is (mostly) cooperating.
It's still gonna be a PITA.
Wanna come by and help?
Old 01-21-2012, 08:41 AM   #5
Rewards Points: 660
Cast iron or PVC?
Wife looked at our future main/master bath project and said 'maybe we could move the toilet here'. I said 'it is on a cast iron flange going into a cast iron stack. I am not touching that.'
B
Beepster is offline   Reply With Quote
Old 01-21-2012, 03:17 PM   #6
Rewards Points: 150
Exactly. If it's floor joists underneath and you can just run parallel, easy. If the joists aren't cooperating, difficult.
psilva8 is offline   Reply With Quote
Old 01-21-2012, 04:08 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 566
I think you scared off the OP
Old 01-21-2012, 09:18 PM   #8
Experienced
Naz1298's Avatar
I will probably be able to post pics Sunday. I'm sure it is a slab on grade but not sure how thick. It'll be a porcelain unit. Pretty much the whole room will be remodeled except the Sheetrock walls and ceiling.
TarheelTerp...any chance you're in the Houston Texas area and not North Carolina....
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Relocating toilet Whaler Man Plumbing 0 02-23-2011 04:54 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Relocating a Toilet newmex999 Plumbing 5 12-24-2009 06:57 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
