Relocate Toilet Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2009, 11:12 AM   #1
relocate toilet drain
i want to move the toilet to the other side of the room. walls and floors are removed, and the toilet will be on the other side of the drain/vent stack. my question is, can the drain have any 90 degree turns in it?? because the existing drain is copper and it is hard to access the stack to cut in a new location. can i just cut the old part out leaving enough pipe to put a 90 turn towards the new toilet? i hope this desription makes sense thanks for any help guys
mike
boddah is offline   Reply With Quote
Old 01-31-2009, 02:12 PM   #2
can you post a picture or a drawing?
Long turn 90's are OK in most cases like this.
II Weeks is offline   Reply With Quote
Old 01-31-2009, 02:32 PM   #3
this is the existing toilet and the copper drain
this is where the drain ties into the stack
and this is a pic of where the tolet will go in relation to the existing spot, it is going where the old drain for the tub was.
Old 01-31-2009, 05:17 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Ayuh,...
The turns aren't so bad as what looks to be an Awlfully Flat run across that far...
Old 01-31-2009, 06:21 PM   #5
There is no code thats says you can't use a 90 as long as its a sweep(a long turn 90) they sell sweeps or you can use a street45 and a regular 45 together to get the long radius you desire.
zosoplumber is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
relocate toilet drain in basement kimmyb Plumbing 1 01-11-2009 12:17 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Commerical Building - Install Drain under toilet? TransTech Plumbing 4 02-25-2008 11:08 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
