Relocate Toilet On Concrete Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2013, 08:34 AM   #1
Rewards Points: 12
Relocate toilet on concrete slab
I've currently got four full bathrooms in my house. I really only need 3-1/2. I've also got a very small laundry room. I think the solution is to convert the current laundry room to a 1/2 bath, and convert the current full bath to a laundry room. These rooms are adjacent to each other. My biggest obstacle would be relocating the toilet. I have a concrete slab and would need to break up the slab to install the new drain piping for the toilet. Any comments on how difficult of a job this would be? Thanks in advance.
txtig is offline   Reply With Quote
Old 08-20-2013, 09:22 AM   #2
MarginallyQualified
Rewards Points: 2,464
It's more about the work being dirty noisy and heavy.
And of course rather unforgiving if you miss a step.
Old 08-20-2013, 10:01 PM   #3
Rewards Points: 1,016
Post tension slab?
____________
Vince
Old 08-20-2013, 11:13 PM   #4
Rewards Points: 12
Yes. I believe that it is post tension.
Old 08-21-2013, 09:28 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 986
Very simple or extremely complicated,??? i would get a camera in there and see what you got, many factors to consider, drain layout, material. branched combinations, etc.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-21-2013, 10:10 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
If it is post or pre tensioned slab then the Building Department would possibly want to see your plan for breaking up the slab without possibly knocking into or cutting any of the tendons.
Then they will want to see a detail on how you intend to compact the ground and what is used for the compacting and how you patch the concrete that you cut or break.
Check your garage slab around the big door to see if there are any embossed letters in the slab stating that it is a PT slab.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Hardwood over concrete slab alessandrot Flooring 26 06-16-2012 11:05 AM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 06:56 AM
Need help for raising level of tile for concrete slab. JakeN Tiling, ceramics, marble 5 03-15-2012 02:38 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
