Reinstalling Vanity Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-30-2010, 11:17 AM   #1
reinstalling vanity sink drain
how tight should i make the nut under the flat metal washer and rubber flange on bottom of the sink?
jgramlich is offline   Reply With Quote
Old 11-30-2010, 11:41 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,... Tight enough as so it don't Leak....
Old 12-01-2010, 12:41 AM   #3
Picky Plumber
I use plumber's grease on the washer and putty under the flange. Tighten it until it is snugged up really good and make sure the flange-(part of the drain you see above sink)- is in contact with sink all the way around (no gaps)
Ther is definately a such thing as over-tightening especially if you have a sink made of vitreous china or plastic.
Plumber26 is offline   Reply With Quote
Help: Kitchen sink drain is clogged with grease cips Plumbing 5 03-16-2014 11:43 PM
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 01:14 PM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 09:36 PM
Bathroom Sink Drain (Broken from wall to Ground) bli182nk Plumbing 2 01-11-2009 08:52 PM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
