Reinforcement For Leaking Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2009, 10:15 AM   #1
Reinforcement for leaking pipes
Anyone ever put tape, solder, or clamps on a pipe as reinformcement before or after it leaked?
jonas is offline   Reply With Quote
Old 03-20-2009, 11:20 AM   #2
HVAC / Plumbing
all piping should be supported with the proper strapping... not tape
kenmac is offline   Reply With Quote
Old 03-21-2009, 03:06 PM   #3
Rewards Points: 370
There are clamps made with a rubber liner that do fix some leaky pipes. But, they do not work at the threaded/grooved end of pipes. those leaks will just get worse. the pipe clamps are for temporary repair, you will end up replacing the leaking pipe. Note that if you get just enough pipe/fittings to replace the leaker, you will probably find that when the pipe is removed, and replaced, there will be more leaks. We always exclude any pipe repair/replacement that is not noted on our original estimate.
fireguy is offline   Reply With Quote
Old 03-21-2009, 09:03 PM   #4
Rewards Points: 820
That's exactly what happened to me last weekend. I had done some hammering on a stud below a joint, and a few days later I just happened to notice that the pipe was hanging low, and wanted to place a clamp/strap on it. When I pushed up on the pipe, the joint started to leak.
As I started preparing the section for replacement, another joint just broke off.
I ended up having to replace about 35ft of pipe with 3/4" copper.
It was 80yr old plumbing.
Always buy more pipe/fittings than you need for the job.
FW
Ultrarunner2017 is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
Frozen Pipes? Plugged pipes? brokenhammer Plumbing 7 01-16-2009 12:10 AM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 02:18 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
