Old 05-03-2010, 06:51 PM   #1
Wire Chewer
Red Squirrel's Avatar
Regular drainage of HW heater, or leave it alone?
I always hear mixed opinions on this, is it best to just leave it alone, or is it a good idea to drain it every now and then to clean sediment? When I lived at my parents' we never did it, and never had issues. There's one time where the tank did get a leak and have to be replaced, but I doubt that was because we never drained it.
My hot water is clean as far as I can tell, so any real advantage to draining the tank?
Old 05-03-2010, 09:36 PM   #2
Super Moderator
Any newer water heater has a feed pipe that is curved a bit--kind of makes a whirlpool in the bottom of the tank--keeping the sediment from forming.
I don't like flushing the heaters. I've seen more problems caused by opening the spigot than leaving it alone. ----Mike---
Old 05-03-2010, 10:11 PM   #3
If sediment does collect in a gas water heater tank, that forms an insulating layer at the bottom of the tank and the tank bottom itself gets to a higher temperature possibly damaging the glass layer and letting corrosion set in sooner.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 05-03-2010, 10:23 PM   #4
It was a dark and stormy
Yoyizit's Avatar
I have a 5' hose attached to the drain and whenever I need hot water in the basement I drain it out of the heater.
Old 05-03-2010, 10:39 PM   #5
Xtreme DIY'r
Interesting idea, I should run a hose over to my basement sink
Which Gas Hot Water Heater walds11 Plumbing 66 01-16-2010 08:38 AM
Pool timer on an electric water heater...Yes or no? Gusaroo Plumbing 2 09-01-2008 09:13 AM
Wiring tankless water heater TheBossQ Electrical 4 07-11-2008 01:05 PM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 10:37 PM
Convection Heater flyultralite Electrical 3 02-15-2008 01:34 PM
