Refrigerator Water Line Through Concrete Slab? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 10-16-2012, 06:19 PM   #16
Rewards Points: 1,216
Look the dude wants to install a 1/4" ice machine line what's the big deal?
Druidia likes this.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 10-16-2012, 06:43 PM   #17
Rewards Points: 582
yep no big deal but I would 3/8 or 1/2 ...because 1/4" is prone to clog after a few yrs...just my 2 cent....oh and yes concrete is sure of one thing it will crack....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (10-17-2012)
Old 10-16-2012, 10:44 PM   #18
Rewards Points: 12
Update: I plan on running a 1/4" soft copper line within a 1/2" OD (3/8" ID) flexible plastic tube through a groove in the slab. Today I cut a channel into the concrete with the angle grinder and hammer drill (angle grinder was a mess, now I see why they use wet saws for this). The channel about 1" x 1" and 6' long. I have the channel making a gradual curve at both ends so the tubes can emerge from the floor without kinking the copper. I think (hope) that if I would ever damage the copper line, I should be able to yank it out of there and slide another copper line through the outer plastic sleeve.
I have all of the materials and I just need to chip away at some more of the irregularities in the groove so the top of the outer (plastic) tube remains about 1/2" under the surface. Eventually there will be another 1/2 inch of thinset and slate on top of that.
Let me know if anyone has any concerns. I'll share some pics when I get a little further.
Mike.R is offline   Reply With Quote
The Following User Says Thank You to Mike.R For This Useful Post:
ben's plumbing (10-16-2012)
Old 10-17-2012, 07:36 AM   #19
" Good, can't wait to see the pictures".
Old 01-30-2017, 01:15 PM   #20
Rewards Points: 2
Re: Refrigerator water line through concrete slab?
Nice thread. It's a shame he never posted pics. I'm about to do the same things. 1/4" was run along a channel about 3 feet long then under the wall until it reached the fridge. I jack hammered the old floor off and went right through the line. I guess I will look for 3/8" plastic tubing to cover the copper while it channels through the concrete.
ClevelandFlips is offline   Reply With Quote
Old 01-30-2017, 04:26 PM   #21
Rewards Points: 720
I've always wanted a reason to try bending long sweep 90's in pvc to sleeve plastic ice maker/refrigerator line and this would be my reason. I just don't need to at the moment.
Old 01-31-2017, 09:44 AM   #22
Rewards Points: 12
Sorry - it's been a long time. I did complete this job. I started with an angle grinder with masonry cutter to make 2 long cuts. It was a dusty mess, but that helped to keep everything straight when I came through with the hammer drill. I ran the copper through the plastic tube and then filled the notch with cement mix. My thinking was that at some point, someone is going to kink the copper, and this way you can easily pull out the copper tube and slide a new one in, without having to jack everything up. After the cement dried I tiled the entire room. I don't have a great picture of that part. I sold the house shortly after completing the 6 year basement remodel.
I couldn't get the pics to come though from my photo album so I will try to attach them.
Mike
Refrigerator water line through concrete slab?-img_20121016_112406.jpg   Refrigerator water line through concrete slab?-img_20121016_115815.jpg   Refrigerator water line through concrete slab?-img_20121016_124556.jpg   Refrigerator water line through concrete slab?-img_20121018_083549.jpg   Refrigerator water line through concrete slab?-img_20121019_082352.jpg
MTN REMODEL LLC likes this.
Old 01-31-2017, 10:37 AM   #23
ZTMAN's Avatar
Rewards Points: 244
Nice job, I bet the new owners didn't even put a fridge in the location you worked so hard on to run a line, right?
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Tags
concrete slab , copper pipe , refrigerator water line
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 05:24 AM
Removing basement tile and pouring concrete slab tondar Building & Construction 12 11-05-2010 12:28 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 09:55 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
