Refrigerator Water Line Install & Electrical - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2013, 10:28 AM   #1
Rewards Points: 18
Question
Refrigerator Water line install
I am needing to close of a wall which has a refrigerator water line & electrical running through this. I would like suggestions on a proper way of running the water line through the wall, and want to make sure that the installation is "up to code". Does the water line need a certain amount of spacing from the electrical lines? Does the plug closest to the water line need to be a GFCI plug? Does the waterline need to be attached to the studs along its run? Please see picture with notes below:
1. Junction box
Note: Junction box will be moved to the attic
2. Light switch for room & adjacent room
3. Plug pulling power from light switch
4. 1/4" braided water supply hose from kitchen sink to 1/4" copper tube
Note: Braided waterline is fed from opposite wall just below #3. plug.
5. 1/4" copper tube from braided water supply to refrigerator
6. Stranded aluminum wiring from main breaker to clothes dryer
Note: 1/4" copper wraps over aluminum wiring.
7. GCC-P ROMEX 12/2 with Ground type NM-8 600 volts (UL) 344/91 wiring from junction box and light switch.
Note: wiring will be cleaned up while junction box is moved to the attic.
8. Door from Washer/Dryer room to Kitchen
Additional Notes:
The open wall is located in the washer/dryer room
The room sharing this wall (opposite side) is the kitchen.
Home is slab foundation.
Water line is run from sink, through a wall, over ceiling in attic to refrigerator.
sMcGp is offline   Reply With Quote
Old 11-05-2013, 12:47 PM   #2
Rewards Points: 6,652
You really need to run a real water line, either using Copper or PEX for the supply, for the fridge. Also, what is what that outlet being so high? Is this in a basement?
The Following User Says Thank You to gregzoll For This Useful Post:
sMcGp (11-05-2013)
Old 11-05-2013, 01:00 PM   #3
Rewards Points: 18
Thanks for the prompt reply. I will run a copper water line then. This is all old "remodeling" from a previous owner. I removed the sheetrock to see what work was previously done. I do not know why the outlet is so high. I will be moving the outlet to a different location. This is a washer/dryer room on a single level, slab foundation home.
Old 11-05-2013, 05:54 PM   #4
Rewards Points: 1,948
Does it ever get below freezing in Dallas? Water in attic?
Old 11-05-2013, 06:54 PM   #5
Rewards Points: 1,232
The record low seems to be -8F according to google.
Old 11-05-2013, 08:37 PM   #6
It depends on the Winter.
Old 11-06-2013, 09:06 AM   #7
Rewards Points: 18
The temperature will be below freezing for a few evenings during December-January. Several years ago Dallas (East Dallas) had 6 days below freezing (lowest being 15F), but this is rare. The lowest attic temp during this time was 38F. I do regularly check the attic temp during peak hot & cold times as there is one other water line which has been run through the attic prior. I have seen water lines installed through the attic in several demo & remodels that I have worked on in the Dallas area. I understand that installing a dedicated water line would be ideal, but this would require the tear out of a newer remodel on the kitchen and cutting into the slab foundation. Thank you.
Old 08-05-2015, 03:40 PM   #8
Rewards Points: 18
Not trying to bring this thread back to life but wanted to give an update. I used Flexible closed-cell pipe insulation over PEX. PEX used because it was a long run. This was run up through the wall along a stud to the attic. From the attic run back down the wall on the other side of the room to an "outlet box" where the refrigerator was connected. This PEX was then covered by additional attic insulation. Thanks Greg for the suggestion.
Tags
refrigerator , slab , water line
Replacing existing electrical line to outbuilding AL C. Electrical 13 02-02-2013 07:05 PM
install line damage krrgyy HVAC 73 08-04-2011 05:51 PM
Gas Dryer - Install Flex Line and Also No Heat mark2741 Appliances 8 07-05-2011 12:10 AM
How to install an Electrical Outlet in the basement Riley W Electrical 2 07-30-2009 02:51 PM
Whole house fan electrical install shalmi Electrical 3 07-01-2009 11:51 AM
