Refrigerator Water Dispenser - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-04-2009, 03:29 PM   #1
refrigerator water dispenser
On a side by side Frigedaire Refrigerator, After replacing the water dispenser lever and I went to put everything back together I can't get the water tube to go into the hole for dispensing and put the unit together. Does anyone have any ideas on how to get the water tube in ?? Please help Thank-you for your help Lu Ann
tackley is offline   Reply With Quote
Old 07-05-2009, 01:17 PM   #2
No Clear on this but are you trying to feed the flex tube into the release lever and it won't go?
If so, spray the opening for the tube and outside of the tube with cooking spray and the tube should slide in
Chemist1961 is offline   Reply With Quote
Old 07-05-2009, 05:49 PM   #3
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
Water dispenser; please go to this website ! !
http://www.applianceguru.com/reply.php?topic_id=20590
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Frigidaire water dispenser does not work waywestside Appliances 4 09-27-2011 03:20 PM
Hole in granite for filtered water dispenser Paulustrious Plumbing 1 10-26-2008 09:19 PM
Brand New Whirlpool fridge - Water dispenser stopped working!! jpherron Appliances 2 01-04-2008 02:35 PM
Frigidaire fridge water dispenser won't stop nonanon Appliances 1 10-05-2007 09:16 PM
GE Profile Ice Cube Dispenser Problem homebrewer Appliances 1 12-20-2006 11:24 PM
