Refinishing Cast Iron Radiators - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2009, 10:29 AM   #1
I've done a lot of research (on the internet) and it seems a lot a people are stating that you can paint a stripped cast iron radiator with any oil based paint and there is no need to use high heat paint.
Has anyone else found that this is not the case?!
I've painted the same radiator twice oil bases paint, once over latex and once on bare metal and both times the radiator gave off noxious fumes when heated up.
This is my second time stripping the radiator and third time painting it and this time I'm going with the metallic paint which I'm told will not give off any fumes when heated up. The high heat stuff may have worked as well but this advice came from a very experience radiator guy.
Anyway just curious if anyone else has run into these problems.
bird.dog is offline   Reply With Quote
Old 11-05-2009, 12:16 PM   #2
I just used Rustoleoum "Alum" color - oil based
Soon as my heat is on I'll know
Did it always give off fumes?
Or just the 1st time the heat was on?
Steam heat or forced HW?
Do you know what temp is circulating ?
BTW - please do not start multiple threads on the same issue
Old 11-05-2009, 09:04 PM   #3
Refinishing Radiators
Sorry about the two posts was not sure what cat to put this one in.
I used Rustoleum as well and it gave off fumes first time the heat came on. Paint started to come off too.
My system is steam and I think it can get up to 210. May not be a problem with water radiators.
Guy at the hardware store told me that the high heat stuff was for up to 1500 degrees and that regular oil based paint should hold up to steam heat temps. I wish I didn't listen to him.
I will let you know how the matalic paint works out.
Good luck.
Electric Cast Iron Radiators Hardlyable General DIY Discussions 1 01-30-2009 03:55 AM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
shut off valves on cast iron radiators bdw2677 Plumbing 2 10-21-2008 08:07 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
