Redundant Pipe-work - Advice Please - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2009, 06:46 AM   #1
Redundant pipe-work - advice please
The central heating system in my new bungalow was installed many many years ago, the pipe-work consists of a single circuit connecting the radiators which is located in the concrete floor. Ive decided that the system needs upgrading and intend to have new pipe-work running through he loft space and down into each room to connect the radiators.
Im now left with the question of what to do with the existing pipe-work that is in buried in the concrete floor. Should I chase it out and remove it or would it be ok to leave the redundant pipe-work where it is ?
Id appreciate any advice and opinions
Girl48 is offline   Reply With Quote
Old 10-18-2009, 08:06 AM   #2
I wouldn't worry about it. Just make sure you cut off all water supply and cap them and at floor level I would just cut them off level with the floor and maybe put something in them ( possibly grout or silicon sealer)to level the floor off.
SULTINI is offline   Reply With Quote
Old 10-18-2009, 08:21 AM   #3
Once the water supply is disconnected, it doesn't matter what you do with them. Cut off and plug at floor level would probably be best for looks. Make sure you install a vent at the highest point to rid the system of air.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-18-2009, 11:13 AM   #4
Thanks both for your advice. That was the answer that I was hoping for.
pipe for water main. RonFromSeattle Plumbing 3 06-19-2009 12:04 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Hello from Indiana! Irishking23 HVAC 17 01-17-2008 05:49 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
