Reduced Flow Thro New Water Mixers - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2010, 04:00 AM   #1
Angry
Reduced flow thro new water mixers
Our house uses a low pressure water system. Since installing new bath and shower mixers recently (imported chinese), the pressure or flow from these mixers has dropped very noticable. The old mixers that came out are at least 11 years old, or possibly as old as the house which is 25 yrs old. Would the reduced flow be the result of the difference in design of the new mixers compared to the old models?
chillibin is offline   Reply With Quote
Old 05-24-2010, 06:03 AM   #2
Not sure what a "low pressure water system" is???? Normal household pressure ranges from about 35-70 PSI. Modern faucets have flow restrictors built in, limiting flow ot 2 1/2 GPM. This is likely different from the old faucets, not sure if it is a problem, however.
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water flow crazyfox Plumbing 6 04-23-2009 02:50 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Bathroom Faucet Low Water Flow domesticproperties Plumbing 2 07-27-2008 06:01 PM
