Redoing Plumbing - Water Service Line (main) - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2014, 02:05 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 684
Yep, soft K is best. The rest of your questions you asked are area specific so your inspector will be the one to ask
Old 03-31-2014, 03:34 PM   #17
Rewards Points: 119
K-thx folks.
I still wonder, where the soft K comes up from the ground, 'practically speaking'
it's really not needed to be anchored/secured in case it's not 'rigid' enough to hold on to its own?
Also, the shutoff valve is connected to the soft K pipe, so I just wonder
whenever I push/pull the latch on the valve, it wouldn't be too strong that it'd bend the soft pipe (it's only a couple of inches of the soft K coming out from the ground)?
Not really experienced w/ this pipe material so would be great if someone can confirm the soft K is strong enough when using the shutoff valve.
joemc3 is offline   Reply With Quote
Old 03-31-2014, 06:12 PM   #18
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Originally Posted by joemc3 View Post
K-thx folks.
Ayuh,.... It's copper pipe,... even Soft, is pretty hard, 'n rigid,...
Old 04-10-2014, 01:59 PM   #19
Rewards Points: 119
So far so good. Got the pipe thru' the tunnel and hooked up. City inspector signed the sheet. Did not have to anchor the pipe to the stucco. The pipe only comes up above ground for like 2-3".
Have new water thru' the soft K copper pipe now.
The pipe is about 15" below ground. 3" of fill sand placed below the pipe.
I got a yard or more of fill sand. Should I put in like 5" fill sand above the pipe, and put dirt (would be like 10") above the sand to fill to ground level?
Old 04-10-2014, 03:20 PM   #20
Bondo's Avatar
Ayuh,.... It don't really matter,....
Use up yer imported sand to whatever depth ya end up at,...
Then finish off the fill with yer native soil,...
Finish it abit high, as it'll settle,...
Glad to hear it's movin' ahead reasonably smoothly,...
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Switch from 1/2" to 3/4" main water line? SanDiegoGuy Plumbing 10 04-17-2009 07:12 AM
Water softener off the main line? scottyja Plumbing 1 02-03-2009 07:16 PM
