Old 04-12-2007, 05:12 PM   #1
Question Redmodeling basement bathroom
My bathroom has basic bathroom waste facilities, i.e. a toilet and shower drains. However, I want to change it all, i.e. rearrange the pieces. The floor is solid concrete and the main sewer pipe is, i would say, 2-3 ft below. This is a federal style city row-house, all-brick, built 1909 in Washington, D.C., to help with framing a reference.
When it comes to breaking the concrete floor in the bathroom, I was thinking of using a 1" SDS rotary hammer, such as this:
http://www.dewalt.com/us/products/to...roductID=16023
with some masonry chisel bits. Is this the right tool? I am sceptical to use a jackhammer because I fear it is not precise enough and it might cause unwanted cracks outside the bathroom frame.
Also, any other insight would be much appreciated from anyone who has related experience ...
Much obliged,
- a
Old 04-12-2007, 08:24 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
It will take a long time using a chipping hammer, jack hammer is best option.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-13-2007, 09:25 AM   #3
Since I live in slabland Florida and have had the displeasure of ripping through a few slabs, I thought I'd help you out.
When selecting a hammer, first look at how much impact energy the hammer delivers to the surface (2.2 ft-lbs is very low). On a concrete slab, 4" thick, I would not chip with anything that did not deliver at least 10 ft-lbs of impact energy. Therefore, you should get either a good mid-size demolition hammer (makita makes really good ones) or go with the jack hammer.
Secondly, if you are worried about run away cracks while chipping, score the surface of the concrete at least an 1" deep. This can be accomplished by attaching a dry cutting diamond blade to a circular saw. Dry cutting is going to create a lot of dust- so be ready. You could use the dry cutting blade and have somebody with you sprinkling water on the dust while you cut to keep the dust from going everywhere; however, you have to work fast or you will soon find yourself in half and inch of water.
If you have a somewhat large area to rip out, by far the easiest way to rip through slabs is with a concrete cut-off saw, a jackhammer, and a pickaxe. Use the cut-off saw to cut through the slab and establish your perimeter. Then, cut that area into smaller quadrants. After which, somebody will use the pick axe to pull the sections up while you jack hammer close to the center of the piece, forcing the section to crack into even smaller pieces that can then be pulled up completely and hauled away. I hope this helps, good luck, and don't forgot your respirator.
Manuel6 is offline   Reply With Quote
Old 04-23-2007, 09:36 PM   #4
Like said above, score it with a masonary blade in a circular saw, but forget about that rotary hammer and rent a nice big electric jack hammer from Home Depot, you'll be there all day with that little chipper. Old concrete can be like hardened steel.
Mike Finley is offline   Reply With Quote
Old 04-23-2007, 09:53 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yep...Jack hammer...or a demolition hammer....
Tears the concrete up easily......
FWIW - We have this Bosch and love it:
http://www.amazon.com/Bosch-11316EVS...7375912&sr=8-1
- Build Well -
Old 04-23-2007, 10:36 PM   #6
I prefer to cut the area out with a water-cooled concrete/masonry saw. When the slab is cut right through around the perimeter, it's easy to break-up the area you'd like to remove with a large sledge hammer - and you don't have to worry about damaging the slab outside the proposed excavation area. Much less dusty, too; but you'll have some water to mop up when you're done.
Ishmael is offline   Reply With Quote
More On This Topic
We are going to talk a little bit about the demolition that we had to do to get started with this project. As you can see this wall along here has been exposed. You can see the 2x6 construction. We came in and decided where the new door should be into... Read More »
Sawcutting concrete can prevent driveway and walkways from cracking while allowing you to add various designs, such as diamonds and stars. You can use this technique to maintain the quality of your concrete for years. Read More »
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
Measuring the Gazebo Base
Measuring the Gazebo Base by Expert Village
Hi! Welcome back to Expert Village. My name is Charlie Folkman and today we are going to continue building our gazebo. Now the next step is going to be the construction of our gazebo. Now the first thing that we want to do is create the octagon shape of... Read More »
Marble has been a traditional carving stone for centuries and remains a favorite today. Marble is an example of metamorphic rock, a soft stone to carve. The colors widely vary depending on what part of the world it comes from. One of the well known... Read More »
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 11:12 PM
Basement bathroom rough-in tdferguson Plumbing 28 03-23-2008 06:05 PM
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 09:59 PM
basement bathroom heat ktrehs HVAC 3 03-12-2007 05:23 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 01:03 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
