Redid Hot Water Tank Flue... Everything Look Alright? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2010, 11:37 PM   #1
Rewards Points: 27
Redid hot water tank flue... everything look alright?
I redid the flue on my hot water tank. I wanted to a run double walled vent so I could have tighter clearances. I increased the angle, which I read is better, however the pipe straight out of the top is shorter than it was. Everything look kosher?
jailbird371 is offline   Reply With Quote
Old 04-01-2010, 07:41 PM   #2
Rewards Points: 27
So far so good. I'm glad i used the double walled vent.
Old 07-07-2010, 02:01 PM   #3
Rewards Points: 27
everything still seems good...anybody have an opinion?
Old 07-07-2010, 03:26 PM   #4
I would put a hanger or two on that, it doesn't look supported or secured at all from the water heater to the floor penetration. What does it look like outside? Does rainwater have a chance to come down the pipe?
The Engineer is offline   Reply With Quote
Old 07-08-2010, 07:33 AM   #5
Rewards Points: 1,216
Looks a little close to that wood framing and as was stated needs strapping to hold it up even though it seems tight.
COLDIRON is offline   Reply With Quote
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Hot water heater expansion tank? rjniles Plumbing 3 06-21-2008 11:53 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 08:17 PM
