Old 01-22-2013, 02:59 PM   #1
Rectorseal oh shower valve
Reccomendations on thread sealant for brass shower valve? Teflon tape isn't working, I was told by a friend Redctorseal No. 5 is what I need. If not, reccomendations on thread sealant.
Can/should thread sealant it be used on CPVC threads too?
natspawpaw is offline   Reply With Quote
Old 01-22-2013, 03:32 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,.... What are ya screwin' into the valve body,..??
How bad, 'n where is the leak,..??
If it leaks with tape, something is wrong...
Old 01-22-2013, 04:10 PM   #3
sometimes it takes 7 or 8 wraps with the cheap, thin tape. if that doesn't work, something ain't right. rectorseal is good stuff and will work just fine, most plumbers prefer pipe dope anyway.
NitroNate is offline   Reply With Quote
Old 01-22-2013, 04:24 PM   #4
Super Moderator
TFE paste with two wraps of tape should work---
One sure way to spoil a threaded connection is to solder to close to the connection---
Always solder the pipe to the fitting---then cool completely--Them screw it in---if soldering near by--wrap the threaded fittings with a soaking wet cloth.
Old 01-22-2013, 05:28 PM   #5
Brass pex fittings into brass shower valve.
Old 01-22-2013, 05:43 PM   #6
Roofmaster
Hope you didn't over-tighten and crack the casting. Brass usually does not leak even without anything. Its relatively soft.
" A lot of men build things, and a lot of things fall down "
Shower Valve Assembly/Locking Nut rookie49 Plumbing 11 01-10-2013 12:14 PM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 08:07 AM
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 9 05-04-2012 11:56 AM
shower valve weirdness wombosi Plumbing 2 06-26-2010 03:59 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 05:37 PM
