-   -   Rectorseal oh shower valve (http://www.diychatroom.com/f7/rectorseal-oh-shower-valve-169829/)
natspawpaw 01-22-2013 01:59 PM
Reccomendations on thread sealant for brass shower valve? Teflon tape isn't working, I was told by a friend Redctorseal No. 5 is what I need. If not, reccomendations on thread sealant.
Can/should thread sealant it be used on CPVC threads too?
Bondo 01-22-2013 02:32 PM
Ayuh,.... What are ya screwin' into the valve body,..??
How bad, 'n where is the leak,..??
If it leaks with tape, something is wrong...
NitroNate 01-22-2013 03:10 PM
sometimes it takes 7 or 8 wraps with the cheap, thin tape. if that doesn't work, something ain't right. rectorseal is good stuff and will work just fine, most plumbers prefer pipe dope anyway.
oh'mike 01-22-2013 03:24 PM
TFE paste with two wraps of tape should work---
One sure way to spoil a threaded connection is to solder to close to the connection---
Always solder the pipe to the fitting---then cool completely--Them screw it in---if soldering near by--wrap the threaded fittings with a soaking wet cloth.
natspawpaw 01-22-2013 04:28 PM
Brass pex fittings into brass shower valve.
jagans 01-22-2013 04:43 PM
Hope you didn't over-tighten and crack the casting. Brass usually does not leak even without anything. Its relatively soft.
