Reconnecting Gas Line- Corrugated Stainless Steel - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2009, 09:34 AM   #1
Rewards Points: 59
Reconnecting gas line- corrugated stainless steel
I am remodeling my kitchen and had a corrugated stainless steel gas line coming up through the floor into an island cabinet. In order to install the new island cabinet, I had to disconnect the shut-off valve on the end of the gas line to temporrarily push it thru the floor.
Now that I am ready to re-connect the gas line, can I use the same "compression ring" on the old corrugated stainless steel to make the connection? Or do I have to have a plumber make a new connection?
Thanks!
handyman923 is offline   Reply With Quote
Old 08-20-2009, 07:44 PM   #2
If you are talking about CSST gas pipe then it should be done by a plumber who is certified in whatever brand you have.
plumber Jim is offline   Reply With Quote
Old 08-21-2009, 06:20 AM   #3
What Jim said, most localities do not want homeowners working on gas lines
That said, I don't think flex gas lines are allowed to penetrate walls, and there are no gaskets, washers etc., in gas lines, they are flare couplings. DON'T resue old flex lines, or valves.
Kohler Stainless Steel Sink Pitting/Rusting RegeSullivan General DIY Discussions 12 01-13-2013 06:54 PM
Stainless Steel sink ruined? oneand8 Remodeling 6 09-02-2009 10:42 AM
Removing dents from stainless steel refrigerator tripower Appliances 4 02-27-2009 05:47 AM
help me find a stainless steel toilet bowl and ... amakarevic Plumbing 2 01-30-2008 02:37 PM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 07:09 PM
