Reconnecting gas line- corrugated stainless steel
I am remodeling my kitchen and had a corrugated stainless steel gas line coming up through the floor into an island cabinet. In order to install the new island cabinet, I had to disconnect the shut-off valve on the end of the gas line to temporrarily push it thru the floor.
Now that I am ready to re-connect the gas line, can I use the same "compression ring" on the old corrugated stainless steel to make the connection? Or do I have to have a plumber make a new connection? Thanks! |
If you are talking about CSST gas pipe then it should be done by a plumber who is certified in whatever brand you have.
What Jim said, most localities do not want homeowners working on gas lines
That said, I don't think flex gas lines are allowed to penetrate walls, and there are no gaskets, washers etc., in gas lines, they are flare couplings. DON'T resue old flex lines, or valves. |
| All times are GMT -4. The time now is 06:41 AM. |
