Recommended Thermal Expansion Tank Brands - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2011, 09:50 AM   #1
Don't know it all, yet!
Recommended thermal expansion tank brands
I need to add an expansion tank to my HWH after the county installed check valves. Recommendations on brands, sources?
50 gallon, gas, service pressure is 70 psi.
Thanks all,
Richard
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Installing an expansion tank Homerepairguy Plumbing 1 01-25-2011 09:10 AM
Thermal expansion tank placement downunder Plumbing 19 06-08-2010 09:47 PM
Is a Hot Water Expansion Tank required Needagameplan Plumbing 9 04-27-2010 04:09 PM
Plumber installed thermal Expansion tank without adjusting pre-charge markwo Plumbing 2 01-21-2010 01:41 PM
Installing a new boiler expansion tank CoachDad HVAC 0 01-06-2010 02:12 PM
