Recommendation Needed For Jet Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2013, 12:29 AM   #1
Rewards Points: 422
Recommendation needed for jet pump
What manufacturers make the best quality shallow well jet pumps? Our current pump is leaking, and is a 1/2 HP. Generally, is it better to have more HP? A 3/4 or 1 HP pump? It is for our house's main water supply, and is a point well. We have a separate pressure tank. Thanks.
Jim McC is offline   Reply With Quote
Old 08-28-2013, 06:34 AM   #2
Rewards Points: 36
I assume the leak cannot be repaired with a new gasket or fitting? Were you happy with the overall performance of your existing brand? How old is the pump? If you do upgrade in size, be sure to not get one so large that your existing wiring will not be adequate.
daveb1 is offline   Reply With Quote
Old 08-28-2013, 06:40 AM   #3
Rewards Points: 282
IMO, While there are many jet pumps to choose from and all of them will claim they are the best; if possible, replace your jet pump with the exact same model as the old one to ensure compatibility with the rest of your system. To make sure you get exactly what you need, take photographs of the existing pump and tank system, including the old pump nameplate. With help from the sales clerk and the photographs, you can match the replacement pump to the original model, or at least find a comparable model of the same size and with the same pump performance.
jmon is offline   Reply With Quote
Old 08-28-2013, 09:42 PM   #4
Rewards Points: 422
Thanks guys. I think the leak is from a seal. I think it's the original pump(Wagner) from when the house was built in 1975, and they appear to be out of business. I don't want to put any money into repairing this old pump.
Again, are they any pump manufacturers that seem to be above average quality? My neighbor, an electrician said to buy a "Red Jacket" pump.
Old 08-28-2013, 10:33 PM   #5
Rewards Points: 282
Roger that Jim. Going new is always the better option if you can swing it. You won't have to worry about it again for a long time. Red jacket has an excellent warantee.
IMO, they are deffinately above average quality and they been around for over 100 years. Of course it all all depends on how much you want to throw at it. For example, a Flotec does the same thing costs around 200 bucks. Plan on around 400 - 500 for the red jacket. Google red jacket shallow jet pumps for reviews. People love them. Just be prepared for the sticker shock.
Old 08-29-2013, 01:21 AM   #6
Rewards Points: 422
Thanks. Do you have any other recommendations that are cheaper than Red Jacket?
Looks like it's time for a new pool pump; please advise! a1481155 Plumbing 5 08-07-2013 04:14 PM
watts needed to run well pump hankbuck Electrical 7 11-07-2012 10:56 PM
Well Pump pressure switch help needed. slabm7 Electrical 20 11-03-2010 05:56 PM
Direct mount sink pump recommendation kornfein Plumbing 0 04-29-2010 11:49 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
