Recommendation For A Decent Water Pressure Guage - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2014, 08:01 PM   #1
Rewards Points: 1,724
Bought a water pressure guage from a big box store and it didn't last. Looking for a recommendation for a good one to measure pressures from garden hose faucets.
justplumducky is online now   Reply With Quote
Old 08-28-2014, 08:28 AM   #2
landfillwizard's Avatar
Rewards Points: 516
Look here. You should find what you need!
http://www.grainger.com/search/ecata...Asc&sst=subset
landfillwizard is offline   Reply With Quote
The Following User Says Thank You to landfillwizard For This Useful Post:
justplumducky (08-28-2014)
Old 08-28-2014, 05:17 PM   #3
Rewards Points: 2,110
None of the gauges last for a long time. I've even tried oil filled gauges. All break so go with the least costly. Besides the first freezing weather and a bit of water in the gauge you'll feed the trash can.
The Following User Says Thank You to Ghostmaker For This Useful Post:
justplumducky (08-29-2014)
Old 08-28-2014, 05:22 PM   #4
Even if the guage is not attached to a faucet, but just sitting in the truck after using it?
Was thinking about this one, cause it has a five-year warranty. Wrong pic is displayed on the page. It's a 160 psi guage.
http://www.grainger.com/product/WINT...AS01?$smthumb$
Good as any?
Old 08-28-2014, 07:08 PM   #5
Good as any?
Yepper, that was a dumb question.... that's obviously what you meant. Just a bit of water in the guage, then freezing weather - feed the trash can.
Old 08-28-2014, 07:37 PM   #6
Find one with good reviews. And cheap. They are just a trash can item. Buy 2 at a time keep one in the box for a spare. After a while you will know the general water pressure of your work areas and will not need the gauge as much unless inspector wants to see a test.
You could also ask your local water providers they usually know the working pressure in areas. I'm northern Ohio and never had a gauge last for more then a few months.
Old 08-29-2014, 05:35 PM   #7
Here' s a forum where I found a couple of recommendations in a thread titled "looking-for-a-water-pressure-test-gauge-that-will-last."
One was for a Wika guage. User said you can get a 2 1/2" liquid filled, stainless steel back for $40.00 and he says, "They last forever."
Link to the forum:
https://www.ridgidforum.com/forum/me...that-will-last
Here's a link to a random page on a random site, showing a 4 1/2" Wika guage.http://www.dfs-gauges.com/images/sup...A_111.25CT.pdf
Here's a link to another site where you can buy Wika guages:
http://www.mscdirect.com/browse/tn/M...vid=4287924185
The other recommendation (copied and pasted):
"Re: Looking for a water pressure test gauge that will LAST!
Try a Referigeration suction gauge... (the blue one)
Yellowjacket makes a good cheap one for 20-30 bucks.
30" vac-125 PSI range and user calibrateable
They work great for me...
Okie"
Old 08-29-2014, 07:48 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 924
IMO- go back and buy a handfull more and discard as needed.
My luck has been the good ones grow legs and run off.....
The Following User Says Thank You to TheEplumber For This Useful Post:
justplumducky (08-30-2014)
Old 08-30-2014, 09:50 AM   #9
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Check with shops that sell parts for RV's.
Gregg M.
gmaint is offline   Reply With Quote
The Following User Says Thank You to gmaint For This Useful Post:
Old 08-30-2014, 10:29 PM   #10
We have an RV Dealer close by, and they sell parts, but please elaborate a little... why you're recommending their parts. What are they used for on an RV?
Old 08-31-2014, 12:11 AM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 2,140
For the buck....Ashcroft. Especially the 2 1/2" styles.
I do this stuff every day....trust me....Ashcroft....
The Following User Says Thank You to ddawg16 For This Useful Post:
justplumducky (08-31-2014)
Old 08-31-2014, 05:23 AM   #12
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
To make sure that the incoming water pressure is not higher than the RV's plumbing can handle.
Gregg M.
Hot water pressure low (pictures) bluefoxicy Plumbing 4 12-11-2012 07:45 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Well Water Pressure Fluctuation cforbes Plumbing 13 10-01-2012 06:52 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
