Recomendation Toilet Rebuild Kit - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2009, 09:45 AM   #1
Does anyone have a recomendation for a complete rebuild kit. Also on the water supply andy reason to go with a flang on the supply as opposed to useing a stright cut with the rubber cone washer.
PiedmontNC is offline   Reply With Quote
Old 12-16-2009, 10:18 AM   #2
I am a big fan of Fluidmaster fill valves. Not sure if any total rebuild kits are available by this company. The flapper is the only other part that is normally replaced. The supply tube is normally dictated by the tank connection design. Both types you mentioned work well when installed properly.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-16-2009, 07:11 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Fluidmaster makes a rebuild kit with both the fill and flush valve. Normally the only reason the change the flush valve is the flapper set is pitted and a new flapper still leaks. To change the flush valve you have to remove the tank from the bowl. If you do, I recommend you replace the tank to bowl bolts and washers.
Old 12-17-2009, 08:34 AM   #4
Thank you
Picked up the fluidmaster kit this morninh=g and will tackle this Sat. Thank you for your input.
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 11:14 AM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 02:53 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
