Reclocate Washing Machine , Drain Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-13-2008, 07:33 PM   #1
Question
Reclocate Washing Machine , drain question
I want to relocate my front loading washing machine from one wall to another. The washer currently drains into deep sink. I was wondering if anyone knows of a pump or something which I would be able to hook up to the washer to help the water drain what would be about 10 feet if I moved the washer. Also, since I do not want to jack hammer the concrete slab, the pipes would be going up into the ceiling and down. I am not sure if this is possible? Any advice?
Any information would be greatly appreciated.
ekimak0930 is offline   Reply With Quote
Old 09-13-2008, 08:40 PM   #2
I have never seen a set-up like that done. You would need a pump that connects to the washer.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-14-2008, 08:29 AM   #3
So there is a pump I could hook up to the washer. Would you be able to tell me what the pump is called.
Thank you so much
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
External Lint Filter for Washing Machine ? Piney Appliances 2 05-03-2007 12:28 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
