Reclaimed Water Pipe (Purple PVC) Repair And Glue Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2008, 08:01 PM   #1
Reclaimed water pipe (Purple PVC) repair and glue question
I need to repair one of my septic lines that is purple pvc pipe. It says reclaimed water pipe, can I use regular collars and a short piece of regular pvc to repair it? Is the glue the same?
TIA
Stan.
smcmurrey is offline   Reply With Quote
Old 07-07-2008, 09:07 AM   #2
http://www.vtpipe.com/Products/Purple/Purple.pdf,, hope this helps you, got it from google search, seems to have info on the connections to use, good luck
DUDE! is offline   Reply With Quote
Old 07-07-2008, 10:58 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
PVC is PVC no matter what the color, and PVC specifically requires PVC primer and PVC glue. You can do exactly what you said. No problem.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-07-2008, 10:49 PM   #4
Thanks for the help, I used regular pvc and blue glue since it was wet.
Stan.
