-   -   Reclaimed water pipe (Purple PVC) repair and glue question (http://www.diychatroom.com/f7/reclaimed-water-pipe-purple-pvc-repair-glue-question-23263/)
smcmurrey 07-06-2008 07:01 PM
I need to repair one of my septic lines that is purple pvc pipe. It says reclaimed water pipe, can I use regular collars and a short piece of regular pvc to repair it? Is the glue the same?
TIA
Stan.
DUDE! 07-07-2008 08:07 AM
http://www.vtpipe.com/Products/Purple/Purple.pdf,, hope this helps you, got it from google search, seems to have info on the connections to use, good luck
Mike Swearingen 07-07-2008 09:58 AM
PVC is PVC no matter what the color, and PVC specifically requires PVC primer and PVC glue. You can do exactly what you said. No problem.
Good luck!
Mike
smcmurrey 07-07-2008 09:49 PM
Thanks for the help, I used regular pvc and blue glue since it was wet.
Stan.
