Old 08-18-2007, 08:47 PM   #1
recirculating hot water problem
The water to our building was knocked out by the sewer repair crew. Since then our recirculating hot water does not seem to be working properly. We get hot water only after running the faucet for a several minutes. This was not the case before the water from the street was knockd out for about 2 hours. I am using a TACO Recirculating Cartridge type pump but not sure how to tell if it is working properly. Any help in this area would be appreciated. When the hot water does flow the temperature of the water is correct. Two other condo owners in the building are not having a problem. We each have our own system.
cliff is offline   Reply With Quote
Old 08-19-2007, 08:38 PM   #2
Custom Cabinet Maker
Cliff; sounds like there is air in system. bleed the system and you should be fine
skymaster is offline   Reply With Quote
Old 08-20-2007, 11:45 AM   #3
Your suggestion to bleed the tank worked like a charm. Now back to a normal operation. Saved me taking apart the pump etc. Thanks again for the help and fix.
Old 08-20-2007, 12:40 PM   #4
Cliff, u r welcome somedays I actually get it right
Jack
More On This Topic
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
If you like putting things together with your hands, a career as a plumber might be for you. Plumbing is a highly skilled profession and one that will always be in demand. Plumbers install, maintain and repair the systems that keep our water flowing... Read More »
Hi my name is Jon on behalf of Expert Village in this video clip we will be turning on the water and inspecting our work. If you recall from the beginning of our problem we had a bathtub faucet that leaked, our first point of inspection is just to take a... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
water pressure problem rgmetro Plumbing 6 04-09-2007 04:57 PM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Water Delivery Problem amadis Appliances 6 12-20-2006 11:22 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
