Recirculating Hot Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2013, 11:27 PM   #1
Still Learning
recirculating hot water line
Hi, our apartment building is having hot water issues. Some apartments including mine have 50 degree water coming out of the hot side. I replaced the recirculating pump and the return temp is still 50. My question is do you think that the pipes being pex in a crawlspace under the apartments cool to 50 with the pump going or should I look for a bad mixing valve somewhere? It's probably about 0-5 degrees outside but I know the pump is working. It's the same temperature in the crawlspace as it is outside. Any suggestions?
thehvacguy is offline   Reply With Quote
Old 01-15-2013, 11:45 PM   #2
Rewards Points: 13,446
Drain some water out of the bottom if the tank to see it's it's hot.
Old 01-15-2013, 11:47 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 546
It's 5 degrees in the crawl and you still have running water?
Old 01-16-2013, 06:17 AM   #4
Lightfoot's Avatar
Rewards Points: 272
my thought too E
that has to be a record for LA
Lightfoot is offline   Reply With Quote
Old 01-16-2013, 06:54 AM   #5
Rewards Points: 4,796
Not sure exactly what your problem is or even exactly what your question is, but if your question is if PEX is causing your low water temperature, the answer is definitely not.
jeffnc is offline   Reply With Quote
Old 01-16-2013, 07:54 AM   #6
Might want to check if the water heater is even working.
Old 01-16-2013, 09:30 AM   #7
i assume that this is a circulator for domestic hot water. i would check the check valve on the recirculating line. if it is stuck open when you open a faucet it will pull water from the bottom of the tank depending on pressure drops on the lines. we always used a spring check on recirculating lines.
Old 01-17-2013, 06:49 PM   #8
Still Learning
How do you check a check valve??
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Water supply line blackhemi Plumbing 4 04-09-2011 08:18 PM
Removing Water Line Obstruction Mickey53 Plumbing 11 12-15-2009 11:39 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
