Recirculating Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-01-2005, 06:35 PM   #1
Recirculating hot water
Hi all,
I'm new to the site. Looks like it will be real informative.
We had a new home built about 1.5 years ago. It has 2 hot water heaters in the basement. They are some distance away from the master bathroom so they installed a recirculating line so we would have instant hot water in the bathroom. It has worked great for about a year but lately we've noticed it takes a long time to get warm water. Someone told me it may need bled again. I've tried but was unsuccessful. Can anyone shed some light on this?
Thanks,
Mike
KTMMIKE is offline   Reply With Quote
Old 09-02-2005, 12:20 AM   #2
Contractor
Many recirc systems use pumps. Have you checked that?
Teetorbilt is offline   Reply With Quote
Old 09-02-2005, 10:05 AM   #3
I'm pretty sure it doesn't use a pump. At least I've never seen one or heard it run. Basically one insulated pipe runs out the top of one heater to the bathrooms then back to the bottom of the other heater.
Thanks,
mike
Old 09-02-2005, 11:40 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
without a pump, or an open water line, there is nothing to move the water. I'm with teetor. Check for a pump somewhere.
jbfan is online now   Reply With Quote
Old 09-02-2005, 01:25 PM   #5
Ok, I'll look into it.
Thanks,
mike
Old 09-02-2005, 03:04 PM   #6
Contractor
It COULD be a convection system but I doubt that it would quit working that quickly. Look for anything with wires running to it. I have seen them under sinks and other places.
Old 09-02-2005, 10:19 PM   #7
Sounds like you have a gravity recirc line which does not require a pump. The water line at the bottom of the heater should have a check valve on the horizontal that needs to be cleaned or replaced.
plumguy is offline   Reply With Quote
Old 09-06-2005, 10:36 AM   #8
I'm pretty sure it is a gravity line. I do not see any wires or pump. I think I saw the check valve you're talking about. I'll give it a shot.
Thanks a lot!
mike
Old 09-07-2005, 09:29 AM   #9
Thanks plumguy!
You solved my problem plumguy! I checked the valve last night & sure enough it was stuck with a little corrosion & such. I cleaned it & we had instant hot water this morning. Thanks so much & thanks to everyone for replying.
-mike
Old 09-07-2005, 10:03 AM   #10
jbfan's Avatar
Rewards Points: 490
plumguy explain to a dumb ole electrician how this system works.
Old 09-07-2005, 03:04 PM   #11
If you do a search out here, you might find my explanation. If not, do a google search and you should pull up some articles on it!! I don't have the time right now, otherwise I would explain it too you!! Let me know what you come up with!!
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 01:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
