Recirculating Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2010, 12:12 PM   #1
Unhappy
Recirculating hot water
I just replaced my son's 50 gal natural gas hot water heater. I thought it would be a cinch until I realized the previous hwh had another copper line(1/2') running from the lower water valve (clean out). As I had never seen this type of installation and after asking many questions I learned this additional line was a gravity hot water return line used to assist in delivering faster hot water in a master bath addition.
My problem now is the hot water to the master bath takes a long time to heat since the new hwh was installed. I tried to hookup system exactly like the old one. I even installed a new check valve and lever turn off. Is there a way I can verify my installation process? HELP?
jerryj is offline   Reply With Quote
Old 01-18-2010, 05:07 PM   #2
What kind of check valve did you put in (e.g. - spring?/swing?) Is/was there a circulator (pump) on that line?
If the recirc was operating on convection alone, a spring-check would be too much resistance and the water will not circulate without a pump.
Ishmael is offline   Reply With Quote
Old 01-18-2010, 07:32 PM   #3
I believe the check valve was a swing type. I also drilled a 1/8" hole in it to assist with flow.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
