-   -   Recirculating hot water (http://www.diychatroom.com/f7/recirculating-hot-water-62178/)
jerryj 01-18-2010 01:12 PM
I just replaced my son's 50 gal natural gas hot water heater. I thought it would be a cinch until I realized the previous hwh had another copper line(1/2') running from the lower water valve (clean out). As I had never seen this type of installation and after asking many questions I learned this additional line was a gravity hot water return line used to assist in delivering faster hot water in a master bath addition.
My problem now is the hot water to the master bath takes a long time to heat since the new hwh was installed. I tried to hookup system exactly like the old one. I even installed a new check valve and lever turn off. Is there a way I can verify my installation process? HELP?
Ishmael 01-18-2010 06:07 PM
What kind of check valve did you put in (e.g. - spring?/swing?) Is/was there a circulator (pump) on that line?
If the recirc was operating on convection alone, a spring-check would be too much resistance and the water will not circulate without a pump.
jerryj 01-18-2010 08:32 PM
I believe the check valve was a swing type. I also drilled a 1/8" hole in it to assist with flow.
