Recircluating Loop - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2010, 12:59 AM   #1
CKSedg
Recircluating Loop
I am very interested in installing a gravity fed recirculating loop. I think from what I have read I can do it very easily. I have two questions I hope someone can help answer:
1) I have two water heaters---connected in series. Do I connect the return of the loop to the first heater in the series or the second? Or, would it be better to connect the two water heaters in parallel and run the return to both of them?
2) Is it better to return the loop to the water heater on a gradual downslope (where possible), or to return it basically flat, with a vertical drop at the very end?
Thanks!
CKSedg is offline   Reply With Quote
Old 03-04-2010, 02:39 AM   #2
CKSedg
Can anyone help me with the above question?
Old 03-04-2010, 07:13 AM   #3
#1 Pipe it into the bottom of the first WH (the one being fed cold water)
#2 Either way will work just try to avoid going down then up (heat trap)
SuperPlumberGuy is offline   Reply With Quote
The Following User Says Thank You to SuperPlumberGuy For This Useful Post:
CKSedg (03-12-2010)
Old 03-12-2010, 01:26 AM   #4
CKSedg
It works~
Wow! I installed my recirculating system and nothing worked for a few days. Why? I didn't have it insulated. I bought some very inexpensive pipe insulation, put it on in about and hour, and went to bed. The next morning, I was excited to turn on my kitchen faucet and have very warm (not hot) water. If I drill a hole in the flapper of the check valve, will it conduct more water to make it hotter?
Old 03-12-2010, 01:44 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is the check valve going the right direction?
Journeyman Plumber
Old 03-12-2010, 01:17 PM   #6
CKSedg
Yes, I believe it's correct. It should be so water flows from the return line into the bottom of the water heater, right? What is the reason for drilling a hole in the flapper on the check valve? Should I do this? Thanks for your help.
Old 03-12-2010, 05:39 PM   #7
You should'nt need check valve on return if your not running a pump. check on cold water supply would'nt hurt, but if your trying to rely on thermodynamics to circulate water the check valve on return will hurt.
just a guy is offline   Reply With Quote
Old 03-12-2010, 05:46 PM   #8
Yes you should drill a hole in the flapper.
How do you use a loop roller? redline Painting 8 04-02-2013 10:05 AM
How to best filter water for open loop geothermal Jim S. HVAC 6 07-05-2012 05:12 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 01:08 PM
To Switch loop or not to switch loop beezlebub03 Electrical 7 06-17-2008 07:04 PM
loop vent or auto-vent amakarevic Plumbing 4 08-21-2007 01:28 PM
